Loss of coolant sometimes
Old Jul 16, 2013 | 01:13 PM
Pas1147's Avatar
8th Gear
Default Loss of coolant sometimes
I have a 2001 Discovery with 90k. Runs great. For a long trim, 4-5 hours and then return home in 2 days the anti freeze level stays perfect. Around town I add just a little every other week or so. Why?
Old Jul 16, 2013 | 04:15 PM
You have a small leak, perhaps around a hose, or the coolant cap; at eleveated temperatures (slow drivng) the coolant is going somewhere. You can rent/borrow a coolant pressure tester from parts store. Pump up to 15 PSI and let it sit for 30 minutes then look for leaks.
Old Jul 18, 2013 | 04:08 PM
kumbhani123's Avatar
Cant one leave the car running until the pressure builds up then identify area?
Old Jul 18, 2013 | 05:04 PM
An easier way is to rent/borrow a coolant pressure tester at parts store, pump up system to 15 PSI, drink a few cold ones, then look for leak. Cold ones optional, but this time of year, it sounds like a good idea.
Old Jul 18, 2013 | 07:04 PM
Don't put off pressure testing the system before you experience a complete coolant failure.
socrazy2992
Jul 14, 2012 05:12 AM
jgeorge
May 19, 2012 06:24 AM
whurst79
May 31, 2008 05:20 PM
ontheroadagain
Mar 27, 2008 08:10 PM
