Loss of Power Issue with misfire cylinger number 5
Old Nov 16, 2010 | 10:50 AM
Enigma753's Avatar
4th Gear
Problem similar to the above:
99 Discovery with 148,000 miles
I've only had it now for 3 months, then the loss of power and what would seem like missing is happening, the check engine came on this morning, it would flash a little and then stay on steady.
This all just happened this morning, so just about every symptom in the above posts, except for no Antifreeze leaking or low fluid, and there isn't any water in the oil it was just changed.
At this point I guess I need to get to computer to read the codes on it? Any suggestions?
Old Nov 16, 2010 | 01:05 PM
DiscoIIBrandon's Avatar
Yes, go get your codes read for free at advance, autozone, o'reily's, etc.
Then start your own thread and people will help you diagnose, just make sure you get the actual code numbers - ex. P0134
Old Nov 16, 2010 | 08:41 PM
handsome rob's Avatar
I had lost the heater hoses once and it left a little coolant in the boot of the spark plug wire. Every once in a while it would boil the coolant in the boot and then arc to the block, this caused a misfire but at least it was easy to diagnose. Good luck with yours.
06HSE
Dec 10, 2014 04:55 PM
cipher982
Feb 27, 2013 08:59 AM
rickfish90
Aug 24, 2011 02:51 PM
djessopeng
Dec 27, 2008 09:33 PM
ontheroadagain
Mar 27, 2008 08:10 PM
