Lost one and only key to disco :(
Old Oct 19, 2015 | 10:48 AM
  #21
Joemamma1954's Avatar
The 03 and 04 do not have chips either.
You can get a key FOB from this place in UK, will cost you only 180.00 and they send a key and programmer, you send the programmer back and they refund 30.00 and email you the EKA code.
Remote Key Europe Remotekey Europe - Specialists in Key Fob Replacement, Immobiliser Bypass, Key Fob Repair
Old Oct 19, 2015 | 01:12 PM
  #22
LandyMatt's Avatar
I have an '03 SE and had my key copied for $3 from my local locksmith. It works in the doors and ignition.
Old Nov 10, 2020 | 12:23 PM
  #23
Range rookie's Avatar
5th Gear
Originally Posted by GARovee
Well.. What can I say? The keys grew legs and walked off. Looked for them all weekend. Thank god for google and a post on discoweb on how to hot wire a disco. Bought two micro switches and mounted them on the roof console right above the sunroof switches. One acc/run and one to start. A hammer and a flat head screwdriver unbolted the ignition switch and stiffed it up in behind the dash. Didn't cut a single factory wire or harness. No steering lock but hey I have push start now $39 got spent at bestbuy for keyless entry module.. So about 45 bucks total to fix a major f-up. Can go back to factory set up since I cut nothing and damaged nothing when ever I have a few hundred dollars for new keys and fobs and dealer programming.
Can you send me more specific details as to the procedure of the hot wire process ? Micro switches? Where you purchased them and brand name, i am in a similar situation i have the ignition switch removed and steering wheel free to turn and the plug removed from the back of the switch .
Old Nov 10, 2020 | 04:33 PM
  #24
logan_gibson's Avatar
Just buy a whole new ignition assembly from Lucky 8 for less than $80 and it will come with a new key.
Old Nov 11, 2020 | 01:18 PM
  #25
5th Gear
Thank you login_gibson, and i would be able to google Lucky 8 i assume?
Old Nov 11, 2020 | 01:25 PM
  #26
Yes.
https://lucky8llc.com/collections/di...tch-components
Old Nov 11, 2020 | 10:27 PM
  #27
5th Gear
right on ! login_gibson that worked out great with that lucky 8 and under a hundred bucks , what a deal and the satisfaction of knowing I'm not going to be cutting and splicing any wiring or harnesses so i thank you once again
Old Nov 12, 2020 | 08:14 AM
  #28
anytime.
CRdisco2
Feb 25, 2013 12:33 AM
Lowell
Jul 15, 2012 03:02 PM
cipher982
Sep 4, 2011 06:35 PM
pilsner
Apr 7, 2008 03:24 PM
Dahne23
Nov 4, 2007 05:50 PM
