Loud squeal
Old Apr 19, 2014 | 08:07 PM
ninjaff21's Avatar
Default Loud squeal
So as of last night my break pedal has to go to the floor to be able to get any stopping power pumping the breaks doesn't help either. also it seems to be coming from the front right there is a squeal and i can't see it being the pads as they are basically brand new any help appreciated!
Old Apr 19, 2014 | 10:52 PM
Dane!'s Avatar
Check for leaks on the master cylinder, you must have a leak somewhere in order for the brakes to hit the floor. Although the brakes might not be directly related to the squeaking and you may just have two separate problems.
Old Apr 20, 2014 | 10:30 AM
SuperSport's Avatar
It should not completely affect your stopping power, maybe just limit it a LITTLE bit, but I've gotten rocks under the brake pads that make horrible noises that will limit the braking slightly. They usually fall out soon, but I have had to remove one before.
I would also visually verify the pad is not worn out completely. If it's been dragging, it could be gone.
Old Apr 20, 2014 | 02:41 PM
ninjaff21's Avatar
No leaks the brake fluid is perfect but it goes all the way to the floor. this is really odd. I'll check my pads for rocks thats a good idea. my 3 amigos come and go on there own like i get 3 chimes then turn off my car and they go away. shuttle valves starting to fail maybe?
Old Apr 20, 2014 | 06:56 PM
Jared9220's Avatar
Sounds like you might need to bleed your brakes. Do you bleed your brakes with a helper? It is hard to bleed these brakes without someone inside pushing down on the pedal.
Put a tube over the bleeder and run it into a catch container. Have someone push down the pedal while you loosen the bleeder. When the pedal hits the floor have them hold it down until you tighten the bleed screw back up. Then tell them to let off the pedal and pump it back up and hold. Repeat the process 5 to 10 times for each wheel. The more times you do it the more clean fluid you flush the system with. Refill the reservoir with clean fluid after each wheel. Do the wheel in the right order RF,LF,RR,LR
Old Apr 20, 2014 | 10:27 PM
ninjaff21's Avatar
Ok ill trynbleeding and let you know
andrewmcoffin
Mar 1, 2009 02:57 PM
morfa
Oct 31, 2008 07:16 AM
Aquaholic
Mar 16, 2007 03:05 PM
mike.howard
Jul 3, 2006 07:27 PM
BigMike
Mar 30, 2006 09:45 PM
