Low Oil Preassure
Old Aug 12, 2010 | 04:49 PM
ShortTom's Avatar
Originally Posted by snowdude
Is it repairable? i was reading on another fourm if the oil pump dosent explode, but just slows, it will continue to break anyways and not make a difference. I was thinking it would be good for another 100k? im confused?
Very interested in any replies this point as well...I have a D2 within the "death range"...I know the TSB says the only real fix is an engine replacement, but wondering if there's a way to keep it cobbled together with replacement pumps.
Noob explanation please!
Old Aug 12, 2010 | 05:25 PM
timdunbar's Avatar
To change the pump you have to pull out the engine. Why stick the same old engine back in without at least a rebuild? Get it done proper the first time and you only have to pay once.
Old Aug 12, 2010 | 08:22 PM
snowdude's Avatar
I've heard that you cant rebuild the bad blocks, there manufactured wrong, correct or no?
A new Block (used) is around $5000, that why not replace the whole thing.
rewi9d
Apr 12, 2012 06:12 PM
eaglewing
Apr 16, 2011 11:06 AM
tito5590805
Oct 4, 2010 09:11 AM
DooDer
Jan 12, 2010 10:46 PM
