Low Range
Old Mar 7, 2008 | 01:18 PM
certifiedimports's Avatar
Default Low Range
I have an 04 discovery and it is difficult to put it into low range. I have followed the instructions in the book and it does not work. are there any tricks to it?
Old Mar 7, 2008 | 01:35 PM
S4poor's Avatar
Default RE: Low Range
No tricks. Come to a complete stop (I put the tranny in neutral) and push forward on the T-case lever. Maybe let the vehicle roll a little bit, and try again,or try leaving it in gear at a stop.
The other thing could be the linkage is Fubar'd.
Old Mar 7, 2008 | 02:12 PM
http://home.twcny.rr.com/eeibooks/ro...codifflock.htm
This is the same for all Disco's with a CDL, same idea just different years, you need to get under the trk and lube the linkage with your favorite Penatrant/Lube and then work it loose, and then "exercise" it once a month to keep it working good.
You dont need to go off-roading, just engage it drive down the street half a block and then dis-engage it. At least once a month.
mwyoung
Nov 2, 2011 12:28 PM
Skimino Farms
Jul 30, 2011 07:47 AM
wilson96rr
Jan 3, 2009 10:44 AM
Classic89
Aug 10, 2007 08:58 PM
Bene
Aug 30, 2005 09:39 PM
