Lowering the rear for loading with SLS
Old Feb 10, 2018 | 06:48 PM
Big Jim Swade's Avatar
Default Lowering the rear for loading with SLS
Is there a way to lower the rear of an SLS equipped Disco 2 that has factory air springs without the optional dealer key fob. I just installed a motorcycle carrier to my hitch and it would be great if I could lower the rear end for loading the cycle.
Old Feb 10, 2018 | 07:49 PM
OverRover's Avatar
I don't think there is a way without the remote.
But this guy seems to have figured out how to bypass the need for a remote. If you look on the right side of the page there is an instruction pdf and some other info.
Other than providing the links, I got zero for you...but Good Luck!
> Fritzing Project ? Land Rover Discovery 2 SLS height controller
> http://fritzing.org/media/fritzing-r...structions.pdf
Old Feb 12, 2018 | 05:43 PM
Thanks for the info. I might have to look into the dealer for the SLS fob and programing of it.
Old Feb 12, 2018 | 07:46 PM
number9's Avatar
The SLS will lower up to 60 mm (2.36 in) below normal ride height if the button is held.
Is <2 1/2" worth it? If fob cost prohibitive you may be able to plumb into lines and install a drain valve.
Old Feb 12, 2018 | 08:33 PM
Sixpack577's Avatar
Putting a dirt or streetbike on a trailer hitch rack...yes, 2 1/2 " is very worth it. Especially to just push a button and have it lower.
Old Feb 13, 2018 | 12:52 PM
Since the motorcycle hitch carrier sits about 1.5' back from the bumper, dropping the rear springs a few inches will probably drop the motorcycle carrier over 6-8". That would make a huge improvement in loading a cycle by oneself.
pendergastjm
Oct 16, 2017 03:47 PM
jrb
LR4
Dec 7, 2011 06:43 PM
longjon76
Apr 8, 2011 12:29 PM
landroverlr3
Oct 9, 2008 09:39 PM
mazetx
Mar 4, 2008 11:17 AM
