LT230 Transfer Case Replacement - Getting Ahead
Old May 22, 2024 | 12:14 AM
acg's Avatar
acg
Default LT230 Transfer Case Replacement - Getting Ahead
The current LT230 is suffering from an increasing loud high pitched whine. I also lost CDL as well as hi-low function. I am going to tear into the center console to take a peek from above in the next few weeks. The Disco is still driveable. But suspect it could be on its last legs.
The t/case replacement may possibly an Ashcroft new unit with HD shafts, HD cross pins and metal sleeve).
I am ordering the necessary parts in advance for the job, especially when it is hard to source in Canada. A friend has a shop lift in his farm who will help me with the job. I scoured the forum, but have not seen a comprehensive list. I am thinking:
- exhaust manifold to pipe (double up with 2 gaskets per side)
- Extinct's grade 8 exhaust studs and nuts
- M10 x 1.5 x 150 mm bolts in lieu of the factory LRT-41-009 transfer case alignment studs (recommended by XRAD in one of his posts)
- Bolt and nuts for the y-pipe
Am I missing anything obvious that may be needed? Any other removal or installation hints will also be appreciated. Thanks in advance.
Old May 22, 2024 | 11:20 AM
Richard Gallant's Avatar
@acg see if you can rent a transmission jack that thing is pretty heavy.
Old May 22, 2024 | 01:52 PM
whowa004's Avatar
I'm about to pull mine for the first time hopefully this weekend as well...we'll see how it goes. Equal emotions positive and negative about the job but putting a 1.4 case back in that shouldn't leak is going to be very well worth it.
Old May 22, 2024 | 05:13 PM
mollusc's Avatar
Transmission jack is essential. The t-case is way too heavy to handle without one, and you'll put strain on the transmission output shaft.
You will need to remove the chassis crossbar, and the bolts for that will NOT come out. Be prepared to get in there with a grinder.
Old May 22, 2024 | 06:18 PM
acg's Avatar
acg
Thanks for the heads up on the jack. The RAVE also mentioned LRT-99-010.
Just found useful info here on the support bracket on the jack to help with the install:
https://landroverforums.com/forum/di...w-build-58504/
Old May 22, 2024 | 08:12 PM
Extinct's Avatar
You can soak those crossmember bolts in Aerokroil for three days in a row and they might come out. Another option for trans jack is an attachment that goes on your standard floor jack.
Old May 22, 2024 | 10:21 PM
Harvlr's Avatar
Princess Auto has usable transmission jacks for fairly cheap. Maybe you have one in the Valley?
Old May 23, 2024 | 08:26 AM
keninnc's Avatar
Those crossmember bolts are made from oatmeal ....get the grinder ready.
Old May 25, 2024 | 10:43 PM
Discorama's Avatar
I replaced all my cross member bolts because some heads were rounded. I got zinc plated 10.9 bolts from McMaster and added a bit of copper grease on the threads.
austinlandroverbill
Nov 19, 2022 07:24 AM
Brandon318
Oct 16, 2021 02:23 PM
94svt50
Dec 30, 2014 03:09 PM
Walko327
Apr 1, 2013 05:39 AM
dansgt
Feb 7, 2012 08:18 PM
