Lug bolt size: 27mm or 1 1/16"?
Old Feb 15, 2017 | 09:25 AM
LR03NJ's Avatar
Originally Posted by mollusc
If you've seen the nuts without the caps, you'll understand the cosmetic reason.
I have seen in the Jeep and was bad. long time ago, had AAA replaced tire and he called another AAA tow truck. The 1st said, his cross wrench wont fit. Thinking they have all the tools fot that.
Old Feb 15, 2017 | 08:46 PM
Alex J's Avatar
If they aren't messed up 27mm but if you have had a hack touch them in the past 1 1/16" might work better. I think I'm going to slowly replace mine one wheel at a time because almost all of mine are messed up and even the 1 1/16" doesn't fit well.
Old Feb 16, 2017 | 07:59 AM
austinlandroverbill's Avatar
Just the thought of rounding one of these off really scares me.
Old Feb 16, 2017 | 08:21 AM
number9's Avatar
You can by a full set for a reasonable cost from L8 or their eBay store. Removed all my covers over a year ago, bought a new set and have yet to install them. The naked nuts are more functional and don't look bad after a week of getting used to a change.
Old Feb 16, 2017 | 10:15 AM
Alex J's Avatar
Usually what happens is the stainless cover gets messed up but the steel lug nut is fine so worst case you can pull the cover off and still get the lug nut off, it will just be a smaller size socket.
Old Feb 16, 2017 | 10:16 AM
Alex J's Avatar
True but grabbing a couple good ones here and there each trip to the junk yard is free.
Old Feb 20, 2017 | 01:04 AM
AZRover's Avatar
Originally Posted by Jeff Blake
1 1/16 works perfectly for my nuts
Old Jan 16, 2018 | 09:52 PM
ggray's Avatar
7th Gear
27mm, and some other info you don't need.
Are the lug nuts on a D1 the same as these specs of the D2?
Old Jan 16, 2018 | 09:57 PM
OffroadFrance's Avatar
Does anyone have a definitive answer as to the size of the D2 lugs?
I want to give my son a breaker bar with a socket for future emergencies, and have tried both sizes and seen each listed as the lug nut "size". I couldn't find anywhere in the RAVE where lug nut size is mentioned.
The 27mm goes on comfortably on my son's D2 lug nuts, while the 1 1/16" is tight but with a little persistence still goes on.
The lugs have seen their share of abuse I am guessing from impact wrenches, etc. and it feels like we are re-squaring them a bit every time we work a 1 1/16" socket on.
Thanks.
Forget imperial sizes, they are history, most, if not all parts of the D2 are metric sizes. If you use a comparison chart some of the metric sizes cross relate to imperial, it's merely luck
PS: Think BMW, VW, new type Rolls Royce, Bentley et al, they are all metric sizes and at one point BMW owned LR and indeed own Rolls Royce whilst VW own Bentley.
Old Jan 17, 2018 | 05:12 AM
abran's Avatar
27mm but the thread size is different.
