Lug Nut Question
Old May 21, 2009 | 03:58 PM
AK Rover's Avatar
Default Lug Nut Question
Does anyone know the lug thread size and pitch on a D1? One of the studs on my spare carrier got messed up and I need to get the die to fix it.
Old May 21, 2009 | 05:03 PM
NiteTrain's Avatar
you can pick up a thread pitch gauge at any automotive store
Old May 21, 2009 | 06:21 PM
AK Rover's Avatar
Problem solved. Took a spare lug nut down to the hardware store and found a bolt that will fit. Found that it is a M16x1.5 threads.
Old May 21, 2009 | 07:01 PM
RoveringAgain's Avatar
As long as we have a lug nut thread, what's the REAL difference in the lug nuts with "nipples" on them used on the spare, and the lug nuts without used on the actual road wheels???
Old May 21, 2009 | 08:37 PM
The spare lugs not will NOT fit on the road wheel threads.
Old May 21, 2009 | 09:22 PM
NiteTrain's Avatar
hah! finally, an advantage the DII has over the D1
Old May 21, 2009 | 09:37 PM
vmann7's Avatar
While we're on the subject why are the disco lug nuts such a different design from all the others I've seen? I've always wondered, LOL.
Old May 21, 2009 | 09:57 PM
NiteTrain's Avatar
they're hoping you'll go to the dealership and pay $24/each for them
Old May 22, 2009 | 11:33 AM
Uh-oh.... I'm in trouble then, because the P.O. left me with one wheel which has a spare lug nut holding it on. Crap. I guess I'd better pull that one off and see what the damage is.
And here I was looking forward to a relaxing weekend...
Old May 22, 2009 | 11:38 AM
hazletbassist89's Avatar
It probably didn't do any actual damage yet, the problem with using the spare lug nuts is that they aren't designed to handle the stress of being on a road wheel, only to keep the spare from flying off your back door and into that Civic that shouldn't be tailgating you. Assuming it hasn't done any damage yet just buy another regular lug nut and replace the spare with it and you should be good. :P
Classic89
Apr 22, 2020 03:05 PM
microbc
Aug 13, 2013 08:17 PM
mattmo78
Mar 29, 2013 11:06 AM
DiscoBlanco
Sep 20, 2011 08:50 PM
farley5150
Feb 20, 2005 11:17 PM
