Air coming from the vent
Old May 22, 2009 | 01:20 PM
yuenie's Avatar
Default Air coming from the vent
I would like to get some info from you guys to see if my D2 is unique....
If I adjust the temp digits on the a/c to 18-22, then SWITCH OFF the a/c and drive, I can still feel a little breeze coming out from the vent. The temperature of the breeze is close to the outside temp.
But if I adjust the digit to 28, then SWITCH OFF the a/c and drive, I can feel the warm breeze even if it is snowing outside.
So my puzzle is : the a/c is actually still working even I have pressed the "(|)" (power) button on the a/c unit?
If this is the case, it may explain why my refrigerent is running out in a week.
Thanks in advance.
Old May 22, 2009 | 01:49 PM
CCROVERSE01's Avatar
On my D2, when off, still has a little air coming through. Temp is whatever engine bay is.
Don't know celcius in F.
Old May 22, 2009 | 02:18 PM
yuenie's Avatar
sorry, my D2 is in degree cel.
18 is the lowest before the number turns to "LO"
28 is the highest before the number turns to "HI"
Thanks.
Old May 22, 2009 | 02:23 PM
All vehicles have to have a given % of air coming thru the evnts, on or off, in the case of a D2, sometimes it will be warmer them normal and that too is normal do to a design error. Some people disconnect the heater hose and by-pass the system during the summer to keep the incoming air cooler.
Old May 22, 2009 | 04:23 PM
yuenie's Avatar
Thank you.
That means my D2 is normal.
But at the same time it means the refrigerent is leaking somewhere.
Old May 22, 2009 | 05:22 PM
http://www.roverparts.com/TechTips/T..._C_to_F_D2.cfm
Print that page and stick it in your glove box, you will need it after you replace your battery when it goes bad.
When you tuen the HVAC off while set to heat then it goes into standby and because heat was the last thing that you wanted it allows heat to still come in as the road air pushes through the vents.
Same thing when set to cold.
As for using so much R-134a, running the A/C or not has nothing to do with it, you have a serious leak that needs to be addressed.
JavaDiscoII
May 16, 2010 03:34 PM
APSIS USA
Apr 30, 2008 12:21 PM
ggushee
Mar 31, 2007 11:58 AM
