M&S lights flashing and limp mode, is 13.4 volts at the battery when running enough?
Old May 25, 2016 | 07:29 PM
mln01's Avatar
Ouch.
Diagnose. Diagnose. Diagnose.
Old May 25, 2016 | 08:57 PM
bcolins's Avatar
Originally Posted by Charlie_V
I bought a new transmission years ago based on the same problems and the day after the expensive replacement (parts and labor then because I was an idiot and could not do it myself) I had the same problem. It was the f ing battery. I'll never get over that. Ever.
Dang,....that had to hurt.
Old May 25, 2016 | 09:24 PM
Charlie_V's Avatar
It was 10 years ago but I'm still pissed. Hahaha. Never forget!
The shop went out of business before I could burn it down!
Old May 29, 2016 | 03:01 PM
akkisu's Avatar
3rd Gear
I was also a victim of the M & S lights flashing. Mine would typically only flash when shifting from Reverse to Drive. I changed the battery, no good. It would sometimes go days without a problem and then all of a sudden just start flashing. I finally decided to go with the neutral safety switch replacement (old one was all corroded) and it seems to be good as new.
Old May 30, 2016 | 06:36 PM
mln01's Avatar
Sorry for overlooking this before. P0705 is "Gear position switch,
incorrect outputs." I would still, however, ensure good voltage (i.e. 13.6+ volts) before replacing the XYZ switch.
Old May 30, 2016 | 07:33 PM
bcolins's Avatar
I ordered an alternator earlier today.
Old May 31, 2016 | 02:13 AM
batard's Avatar
I've also been having M&S issues. My voltage while running was 14.2. I also cleaned up the terminals and replaced the negative one for good measure. I'm now replacing the XYZ, based on a shop's advice. It sounds likely to be an alternator issue for you, given those voltage readings.
Old Jun 6, 2016 | 03:55 PM
bcolins's Avatar
Default Update: Alternator replaced,....seems to have fixed it.
Ordered a reman Bosch unit out of CA. $140,....shipping included and no core charge / exchange. got the alternator installed, 14.2 volts now,......about a 5 mile drive,.....problems seems to be fixed.
Brian in Austin.
Old Jun 6, 2016 | 06:32 PM
Charlie_V's Avatar
Brian in Austin.
Nice fix. Congrats.
Meldav32
Feb 23, 2022 06:53 PM
khuds308
Feb 26, 2018 03:22 PM
dis2creek
Oct 9, 2016 12:25 PM
halbertse
Aug 8, 2015 07:42 PM
yarddawg
Dec 10, 2007 05:19 PM
