MAF Plug
Old Oct 31, 2018 | 07:30 AM
  #41
CollieRover's Avatar
Originally Posted by Jason_B
Damn sorry you are having trouble still Collie. I am thinking of changing my fuel pump just in case.
I changed out my CPS to be proactive and if that’s it it did not pay off!
I regret not just using Bosch sensors, but as yet undetermined.
Old Nov 1, 2018 | 09:09 AM
  #42
Nothing back from my poor mechanic. I give Marvin credit he works on it.
Old Nov 1, 2018 | 01:21 PM
  #43
I just got off the phone with Marvin. Apparently there is a problem with a misfire, all cylinders and so there is an issue with the harness. The entire coil pack is not getting a signal. Fix is $950 replace applicable harness, and reprogram.
To my knowledge both a bad TPS and CPS can cause this. Should I try to put in a new Bosch CPS first? The TPS is a new Duralast.
Says the sensors have all checked out. What do you guys think? Could it be a bad ground or something related?
This guy has always been right.
Old Nov 5, 2018 | 07:07 PM
  #44
Got her back.
CPS, MAF and ECT Sensor wirinvvjad to be fixed. I may have done something during HG adventure, but who knows.
also, the BCU was not communicating properly with the ECM. Marvin talked to whoever his scanner company is, or someone, said that I should not use scangauge for 6 weeks or so. Something about giving the computer some time to get set or something. I don’tknow. Not a big deal the cooling system is in great shape, but what am I going to do if I can’t stare and obsess about temps, voltage, gas mileage and rpm’s?
just happy she is fixed. Took them 2.5 days of work, and Marvin has never failed me.
Old Nov 6, 2018 | 09:57 AM
  #45
Jason_B's Avatar
Great to hear Collie!
I know how emotionally invested I can get in my truck so I am sure you are feeling better. Sometimes it is best to hand her over to someone who has the time and resources to sort out a tricky problem.
Hope this is the last major issue for at least a while!
Old Nov 6, 2018 | 11:52 AM
  #46
I hear that! It really runs awesome, and it took them 2.5 days, meaning it would have taken me a month. That's two experienced mechanics with heavy duty scanner, and proper equipment.
how is your truck running? Are you loving the upgraded Cam?
Old Nov 9, 2018 | 03:38 PM
  #47
So, she wouldn’t start today, got it to the shop and it appears the xyz switch is buggy, so Marvin’s give. Me 2 hour wait. Time for a Guinness and some tacos.
Old Nov 18, 2018 | 12:48 PM
  #48
After Marvin’s wiring fixes, and reprogramming the engine is idling very smooth. As he suggested, I am not connecting the scangauge so I don’t know exactly what the idle is, but the ECU seems to be adjusting to all the mods.
attworth
Jun 18, 2023 04:09 PM
boxsterrs60
May 19, 2019 12:39 PM
mfielding2
Feb 20, 2019 11:04 PM
twsnow
Feb 25, 2012 06:04 PM
tomfraser
Mar 19, 2009 09:25 PM
