Major 60k Mile Service - Revised
I am. I trust the oil pump to 100k, but I've seen a hand full fail around 120k. The way I see it, go ahead and do it alwvery 60 while most everything is already apart.
Not to say they won't last till 120k. 9 out of 10 will last that long. It's expensive to fix if yourl're that unlucky 10th, though.
That's impressive. I understand that the later the year the worse they get for breaking, but still that they do fail not infrequently in earlier years. I suppose it comes down to each individual engine.
I tore apart an 04 with 128k with a pump gear cracked clean through in three places. My own 03 had a crack forming, though not through, at around 135k when I replaced it. I've seen and talked to other people with failures around 115k-125k. Even the one in RoverMasterTech's write up in one of the sticky's had failed by 110k.
That's not to say my information is universally correct, but I figure better safe than sorry. A $70 oil pump is a lot cheaper than a front cover and all new bearings.
