Many Problems: Leaks, Brake Lights, etc...
Old Jun 20, 2007 | 07:51 PM
nate13's Avatar
3rd Gear
Default Many Problems: Leaks, Brake Lights, etc...
Hello,
I recently purchased a 98 Discovery and have since found many little problems that I am ignorant on as to a fix. Any help would be greatly appreciated.
I know very little about technical terms and things of the sort, but will try and answer questions if needed.
First, the leaks. There is a leak from the "crankshaft seal" (as I was told by someone), after driving approximately 50 miles, I had leaked around a quart of oil.
There is also a leak coming from the power steering box area, no real idea where that is coming from but I don't seem to be loosing much fluid there.
Now, the brake lights don't work...at all. I read the other thread down the page, but that problem prohibited the discovery from shifting out of park. I am not sure if this requires the same fix or not, but I wanted to ask.
The passenger seat (power seats), was reclined today and won't go back up. The seat moves forward and back, but won't "un-recline", I am assuming it is the motor on the seat, but maybe a common/easy fix is available?
The rear windows will go down with the front control, but won't go back up. I browsed over something on "roverparts" that said it was a wiring fix in the glove box, but that fix was for a total lack of control of the back windows. Is this what you would recommend?
In four low, the disco seems to "jump" every once 15-30 seconds. I remember hearing of this problem being more severe, but don't know of the cause of it or a remedy.
Also, I currently have 30/11.5 wheels and they rub on the inside, I was looking at Kumho Road Venture M/T 265/75/16 tires. Do you think these would reduce the rubbing? I can currently turn my wheel one full rotation and an additional quarter turn before I worry about the rub.
Again, any and all help for these problems would be greatly appreciated as I have little auto knowledge and am even more ignorant on specific vehicles.
Thank you for your time and help.
Old Jun 21, 2007 | 07:57 AM
Landzu's Avatar
Default RE: Many Problems: Leaks, Brake Lights, etc...
ORIGINAL: nate13
Hello,
The oil seal needs to be fixed.
The back windows controler is behind the glove box and sometimes can be taken out and fixed .
The seat is most likely the controller.
The tires are to big, the largest but may still may rub is 245/75/16 this is with no lift.
The jumping is more likely the large tires.
The power steering leak is made worse by the over size tires.
Old Jun 21, 2007 | 08:03 AM
Landzu's Avatar
I forgot the brake lights.
If it was the brake switch you could not get out of park.
I would change all the bulbs even if they look good.
If this doesn't work check the ground wires.
Old Jun 21, 2007 | 09:55 AM
Unless you are real mechanical and very familiar with the Disco, I would suggest you find a small local shop and have them give your truck a once over and a estimate for each item that needs repairing.
Mike
Old Jun 21, 2007 | 10:25 AM
98roverguy's Avatar
How many miles are on it? I have a 98 and just curious when all that misery will be heading my way...
Old Jun 21, 2007 | 02:39 PM
nate13's Avatar
3rd Gear
My disco has 122,000 miles on it, but, I don't think many of these problems are normal. From what I have gathered, the previous owner abused it severly. (They may be normal, but again it seems like most of the problems could have been avoided or pampered sooner)
I took it to a local mechanic today, he says that it is leaking from the oil cooler lines and the front and rear crankshaft seal.
Old Jun 21, 2007 | 04:20 PM
I would suggest you degrease your engine, power scrube it, put some engine oil dye into the oil and then get a second mechanic to look at it.
Front and rear seals as a pair of failing seals is not common and damm expensive to repair. You may have a leaking intake manifold causing leaks at both the front and rear of the engine.
Mike
Old Jun 22, 2007 | 11:00 AM
nate13's Avatar
3rd Gear
I degreased and power sprayed the engine the day after I received it and the first mechanic I took it to said just the front seal, but didn't really investigate further.
Yesterday, I took it to another mechanic and he showed me the build-up of running oil down the cooler line, and I have seen the front seal's leak. The rear he said "looks like it has leaked a bit, but it isn't as important as the front 2."
He quoted me around $531 in labor for all 3, $396 of that being on the back seal (8.8 hours). The front 2 are supposed to take approximately 3 hours.
Is there any troubleshooting site or someone that could give information on my passenger seat? It is getting rather annoying fully reclined....
I don't think the previous owner did any maintenance on this Disco, nor do I think she acknowledged any leaks and attempted to fix them prior to them getting more severe.
...should I expect any more problems in the near future or can I hope for most to be done after this?
Spencerfitch
Sep 27, 2020 12:17 PM
06Range
May 8, 2013 09:01 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
jasoncrew03
Nov 15, 2010 09:48 PM
phia@binoco.com
Dec 10, 2006 11:23 PM
