Master Cylinder Replacement
Old Mar 6, 2016 | 10:16 AM
nickm347's Avatar
Default Master Cylinder Replacement
I need to replace the master cylinder on my '01 D2.
Is there a consensus on which one is best?
I'm weary of some aftermarket manufacturers.
I'm considering this one from British Parts of Utah
Land Rover 1999 2004 Discovery Brake Master Cylinder Lucas New | eBay
Old Mar 6, 2016 | 10:55 AM
Alex_M's Avatar
I pretty much just buy whatever new part is cheapest for parts like this. It's a pretty simple mechanism, so there's not a lot to mess up. I'd say that one is perfectly fine.
When bleeding them, bleed before the ABS module first. Crack the nuts leading into it and bleed there before you bleed the rest of the system. That will prevent the ABS module from getting much air in it and you wont have any problems with soft brakes that way.
Old Mar 6, 2016 | 10:56 AM
Charlie_V's Avatar
I think they are all the same but your link points to a good one.
It is cheaper to get a rebuild kit if yours isn't physically damaged.
Old Mar 6, 2016 | 10:32 PM
DiscoCam's Avatar
X2
I rebuilt mine in December and have not had any issues with it since.
Old Mar 7, 2016 | 05:53 AM
drowssap's Avatar
if you going to buy a master go with the OEM after market sux
LRadventure
Aug 27, 2014 03:21 PM
kingnebby
Apr 10, 2011 04:56 AM
bantham1
Apr 1, 2010 10:47 AM
TVO
Mar 15, 2007 12:08 PM
leebuhrul
Feb 26, 2006 03:38 AM
