Meaning of Three 3 Amigos?
What are the three amigos on a 2003 Discovery? Today on a rainy day, my wife called and said she saw these three lights on the dash...TC, ABS, and the Hill Descent lights. I did a search on the forum and I think the three amigos are those things, right?
We have had intermittent brake squealing, but since it has not been consistent I haven't looked any farther into it. Does this mean I should at least replace the brake pads?
Thanks,
David
Thanks,
David
Dust, noise, a bad hub, dirty fluid, bad abs sensor, bad shuttle valve, bad abs module and even more can cause the 3 amigos. So take a look if there is noise or a lot of dust replace the pads (if low) or clean them with brake cleaner. Then do a quart brake fluid flush all 4 tires. Go from there.
