This means I don't have diff lock, right?
Old Feb 18, 2016 | 11:02 AM
batard's Avatar
Default This means I don't have diff lock, right?
My H-N-L shifter has always only traveled forward and backward, but the decal in front of it shows the left-hand shift for CDL. I assumed because I have a 2004 it should have CDL, but that it must be stuck. I decided to get to the bottom of it today, and I believe I don't actually have CDL. I'm not sure whether it came from the factory this way or what, but there's what appears to be a blank where the CDL stuff should be. I put my hand on the transfer case just above where the front shaft connects and felt a smooth surface. I then reached around with my phone and saw the following: Imgur: The most awesome images on the Internet
This seems to show a round blank where the CDL should be. Correct?
Old Feb 18, 2016 | 11:56 AM
abran's Avatar
I'm lost with your photo, I dont think you photographed the right area.
Old Feb 18, 2016 | 12:10 PM
batard's Avatar
I was going off of this picture: http://www.discovery2.co.uk/images/d...mabove_web.jpg
This shows it from above. You can see here the "diff lock spigot" right above where the front shaft meets the transfer case. That's what I tried to take a picture of, and it appears to be a circular blank on mine.
Where else should I be checking?
Old Feb 18, 2016 | 12:16 PM
batard's Avatar
I also think I don't have it based on this video:
The shift **** doesn't have any diff lock indicator even though the sticker does. I'm thinking the internals aren't even in the transfer case because the "spigot" isn't there.
Old Feb 18, 2016 | 12:25 PM
number9's Avatar
That may be the area where the interlock solenoid an neutral warning switch is located on some NAS & Japan models. Link to photo of boxes w/sans CDL.
https://www.google.com/imgres?imgurl...w=1920&bih=928
Can't go by the ****.
acg's Avatar
acg
Here is a pic for your reference. It does appear you do not have a diff lock spigot on the transfer case.
Attached Thumbnails This means I don't have diff lock, right?-s-l1600_1a.jpg   This means I don't have diff lock, right?-s-l1600-5-.jpg
Old Feb 18, 2016 | 12:28 PM
batard's Avatar
There are a lot of arrows in this! But the part I'm taking a picture of (or trying to, anyway) is that assembly just above the front shaft connection. Here's an attempt to describe it: Imgur: The most awesome images on the Internet
This is part of the CDL assembly, no?
Old Feb 18, 2016 | 12:30 PM
acg's Avatar
acg
Yes, the circled part of the CDL spigot. Sorry for the confusion!
Old Feb 18, 2016 | 12:31 PM
abran's Avatar
Your reference photos are obviously correct, I just didn't recognize the area you took a photo of.
Do you have slim roof rails or fat round ones? Slim being 03'
Old Feb 18, 2016 | 12:32 PM
batard's Avatar
Mine seems to be the version on the left. Hmm...
