Melted O2 Sensor! and bypassed fuel inertia switch?
Old Jun 4, 2009 | 12:32 PM
jycsalas's Avatar
Default Melted O2 Sensor! and bypassed fuel inertia switch?
This second 97 Discovery that I am working on has a couple of issues...
Here are two of them
And
So could the bypass be why the fuel gauge doesn't work?
And surprisingly the O2 sensor seems to still be working since it's not throwing a single code.
129k miles 97 Discovery.
here are more pics which maybe some of you can give feedback on it's medical condition...
http://picasaweb.google.com/Landrove...nS97Discovery#
Old Jun 4, 2009 | 12:37 PM
okdiscoguy's Avatar
yeah, pretty sure bypassing the inertia switch will kill the fuel gauge.
Old Jun 4, 2009 | 12:49 PM
jycsalas's Avatar
Yeah i wonder who did that? Maybe the PO or last guy who attempted to fix it rigged it so and didn't know to reset it. I'm gonna remove the bypass, reset the switch and see if she still runs and if the fuel gauge works.
Thanks okdiscoguy
Old Jun 4, 2009 | 01:05 PM
okdiscoguy's Avatar
yeahm may be a bad switch.
Old Jun 4, 2009 | 01:15 PM
Bad switch, and it won't effect the fuel gauge operation.
Looks like it is time to rewire that 02 connection, sure won't work like that.
Old Jun 4, 2009 | 04:57 PM
I like their plug for the radiator.
And that is the dryest power steering box I have ever seen on a Rover!!
Old Jun 5, 2009 | 08:08 AM
jycsalas's Avatar
Well i did pressure wash the steering box to locate the leak... but it wasn't THAT bad. =)
Old Jun 8, 2009 | 10:57 AM
jycsalas's Avatar
UPDATE:
I "unbypassed" the fuel inertia switch and reset it and it runs fine. Fuel gauge still doesnt work nor does the tachometer. Upon further inspection of the melted O2 sensor, all the wires/ connections are still good (intact) but i'll still be searching for a used harness to replace it with.
ALL fuses are good.
Old Jun 8, 2009 | 11:13 AM
Check the wiring on the alternator to see if that is what is causing the tack to be in-op.
Old Jul 25, 2010 | 05:40 AM
ducmed's Avatar
8th Gear
I was just wondering if this a bypass of the inertia switch would work? I am just hoping to use it as a temporary solution till I can get a new one...
grandkodiak
Jun 7, 2020 01:37 PM
punkarockaboy
Jul 24, 2012 12:40 PM
sdsilvere38
Dec 3, 2010 10:38 PM
tophur
Feb 11, 2008 12:47 PM
castillo8071
Nov 13, 2007 10:54 AM
