Metal melted between cylander heads
Old Jul 14, 2021 | 09:04 PM
  #31
Alex_M's Avatar
Exponentially, yes. Simply getting new sleeves put in a block without that existing damage is (last I checked, most likely higher now) around $1700-$2000.
Old Jul 14, 2021 | 09:48 PM
  #32
evil_goat's Avatar
Here are my options, what would the estimated cost be for each one? Are there more options?
1. replace engine (the only engine I found was $1,600 how much more would I need to spend installing it)
2. replace block
3. repair block
Also, where can I get an engine? Im in northern California.
Old Jul 14, 2021 | 10:01 PM
  #33
tnrangerover's Avatar
2. replace block
3. repair block
Contact one fo the parts gurus below. they'll get you an engine cheaper probably and can ship.
Virgina: roverguy.net
roverland parts
Paul Grant (google him)
roadsidewerx (Denver)
union jack 4x4 los ángeles (garden grove)
Great Basin rovers(maybe. doesn't hurt to call)
You can also use a 2000-2002 Range Rover 4.6 block, or you can even use a discovery 1/RRC block but I believe the crank position sensor needs to be modified (mounting surface trimmed down). my disco has a 2000 Range Rover block in it.
listen to the folks here. don't even try to repair it. it's a boat anchor now.
Ferrarone
Oct 2, 2020 06:26 AM
blakslee720
Dec 10, 2019 07:18 AM
britguy
LR2
Oct 20, 2019 09:28 AM
britguy
LR2
Oct 4, 2019 08:37 PM
ftlbritish
Build Threads
19
Aug 24, 2017 06:42 PM
