Mileage achieved on 03-04 original blocks?
Old Nov 8, 2014 | 05:54 PM
  #21
cybercop's Avatar
For what it's worth, I know my 126k on my '03 was the original block. I'm the original owner.
Old Nov 9, 2014 | 09:56 AM
  #22
mark d's Avatar
130k on my '04. Started ticking (lifter noise) about 110k, need to do something about that. What are Rhodes leak down lifters?
Old Nov 9, 2014 | 10:02 AM
  #23
RicketyTick's Avatar
You sure it's lifter noise? Do you have a genuine gray 180 t-stat in it?
If not you should try one and see if it helps. Engine runs a little cooler and stops the tick in some.
Old Nov 9, 2014 | 11:31 AM
  #24
04DiscoMike's Avatar
I have an 04 with 160k ..leaking coolant at the moment need to replace HG...but other than that...great ha
Old Nov 9, 2014 | 03:14 PM
  #25
Bom2oo2's Avatar
Hi, I bought a 04 se, 3 months ago had 126k and had fresh shortblock , so I think that's how long the original block lasted, and it was never used offroading, that was the reason I bought it, so I don't need to worry about rebuilding a new block, since it cost's a lot to get a new shortblock, drives very nice, so far , so good.
Old Nov 18, 2014 | 04:04 PM
  #26
mom2one's Avatar
8th Gear
Default My '03 just died
Bought my '03 SE7, in the death VIN range, at 130K and got it to 196K before being told I need a new engine. I've done two HG's already, had the 180 thermostat and had a scangauge to constantly monitor temp. It had recently started drinking coolant with no puddles on the garage floor.
I'm now looking for a LR3...
Old Nov 19, 2014 | 09:11 AM
  #27
Yoops Racing's Avatar
83k VIN was plagued with known issues as well and after HG replaced, the oil pump gears went. She was ticking slightly as well from slipped sleeve. I was 3rd owner... motor was a total mess when I purchased probably suffered over heating more than once as it was in Miami Fl. Apparently not maintained correctly. Replaced with Cannibal V8
Old Nov 19, 2014 | 11:49 AM
  #28
DoubleK's Avatar
Originally Posted by Alex_M
Is there any way to tell if a truck has the original block? Matching Vin to block number or something like that?
^^I've wondered this as well, any info (I called the dealer that serviced it and they don't keep records after 5 years supposedly)? I have 176k on my '03 (not bad vin range) but I don't know for sure it's original ... father-in-law bought it new and remembers paying about $3,500 for "all the gaskets to be done" at some point, whatever that means, maybe it was actually liner work. Seems pricey for just gaskets, but I do all of my own mechanic work so what do I know. I just pulled the front cover due to coolant leak that got worse quickly ... the water pump looks original and was in near perfect condition (perhaps a bit of play), the front main oil seal was leaking (replacing), timing chain was stretched (replacing), the oil pump gears were intact and seemed fine (but replacing them while open), the oil pan looked good (some sludgy substance in very bottom that wouldn't be near the pick-up tube ... good design i think). Overall, every internal oil area I saw just looked varnished.
Old Nov 19, 2014 | 12:13 PM
  #29
drowssap's Avatar
"father-in-law bought it new and remembers paying about $3,500 for "all the gaskets to be done" at some point," that could have been a price for head gaskets and a timing cover gaskets, they quoted me $3433.00 included nothing but gaskets.
Old Nov 21, 2014 | 12:21 AM
  #30
mom2one's Avatar
8th Gear
Default Dead engine at 196 K
It is sitting at The Shop, Norcross, GA if anyone else wants to put an engine in it...
Could kick myself, just changed out the wipers using AB's kit to make them Disco 1 wiper arms for better pressure. Just replaced all the little centers in the wheels with fresh LR emblem caps. Just got the rear ladder too, it was on backorder. Not happy!
slanginsanjuan
Mar 19, 2012 10:07 PM
03discoman
Nov 26, 2010 08:27 PM
lipadj46
Nov 20, 2009 02:37 PM
twmj1953
Apr 23, 2009 07:03 PM
disco12
May 7, 2006 10:38 PM
