Miliage/gear selection LED on dash supposed to be lit?
Old Jun 24, 2012 | 07:50 PM
jafir's Avatar
Originally Posted by grandkodiak
I just noticed (I rarely drive at night) that there is no light that I can find to illuminate the led screen on the dash that shows the miliage and gear selection... is it supposed to be lit all the time, with lights on, or is there a switch somewhere for it?
So in case anyone reads this in the future:
I finally replaced this bulb. The LCD is lit all the time, and then when you turn your headlights on, it dims a bit, and is controlled by the dimmer ****.
Old Jun 26, 2012 | 01:25 PM
grandkodiak's Avatar
was it difficult? im just about at the point where its pissing me off enough to fix haha
Old Jun 26, 2012 | 01:59 PM
jafir's Avatar
Not bad at all. Drop the tilt steering wheel down. Pull the two philips screws out of the cluster hood. (if they are even still attached to anything) pull it forward off of the clips at the dash near the windscreen. Disconnect the electrical connectors for the switches on the left and right side, and the goofy connector wrapped in foam for the dimmer ****. Remove the gauge hood. Remove four philips screws, two on each side and flip the gauge cluster up, you can leave the wires connected. Use a small flat blade or needle nose pliers and give the old bulb 1/4 turn and remove.
sloppyjoe
Nov 28, 2008 04:20 PM
sloppyjoe
Nov 27, 2008 06:17 AM
Lebowski87
Jun 1, 2006 04:23 AM
dbs600
Aug 5, 2005 04:10 PM
DiscoDuck
Mar 29, 2005 10:22 PM
