Minor Oil Leak
Old May 12, 2020 | 03:47 PM
cvhyatt's Avatar
Default Minor Oil Leak
This is a minor leak but one I can seem to get under control. Only a few drips a day but it is annoying. Bigger question is whether this is something I should worry about? Seems like it seeps in both locations. I have verified torque.
Old May 12, 2020 | 08:21 PM
Best4x4's Avatar
Probably a rear main seal seeping
Old May 12, 2020 | 08:31 PM
cvhyatt's Avatar
Thanks Best. Is that cause for concern? Doesn’t seem like a big leak but if it is going to lead to larger issues, I’d much rather take care of it.
Old May 12, 2020 | 09:18 PM
Best4x4's Avatar
They pretty much all leak eventually. I found the rear main on a 4.0L I6 out of a Jeep leak much much worse. Just keep an eye on it, but it should just only seep vs pour out.
Old May 12, 2020 | 09:23 PM
cvhyatt's Avatar
That’s what I figured but wanted to check. Thanks for the quick reply!
Old May 12, 2020 | 09:30 PM
Best4x4's Avatar
no problem!
Old May 12, 2020 | 10:57 PM
Discorama's Avatar
Could it be coming from above? I have some oil in the same spot but I know my valve covers are leaking a tiny bit.
Old May 13, 2020 | 03:17 AM
JUKE179r's Avatar
Since my Disco has been on jack stands for a month now, I noticed the same oil leak area as @cvhyatt . I wiped the area clean and removed the 3-bolts to the tranny circular plate and it was dry in there.
It's been a week since I cleaned up the oil leak area and it's still dry. Weird...
Old May 13, 2020 | 05:31 AM
cvhyatt's Avatar
No leaks from above. I have been keeping an eye on it since I fixed the power steering leak and it is definitely seeping here.
saw this video from AB which seemed to confirm the diagnosis.
ESPN
May 3, 2012 07:42 PM
thehun
Nov 19, 2010 10:22 AM
newdr
Oct 27, 2008 11:28 AM
okdiscoguy
Jul 9, 2007 10:49 AM
