Misfire ‘04 Disco 2
5 and 7 are on different coils, so we can likely rule that out. Did you change wires recently perhaps, maybe you swapped locations? If not, start by swapping plugs with 1 and 3. If that does not work, you need to swap wires with 8 and 6. Then swap coils. After coils swap injectors with cylinders on that are not misfiring.
