Misfire ‘04 Disco 2
Old Aug 9, 2022 | 11:05 AM
Terryboyellis's Avatar
4th Gear
Default Misfire ‘04 Disco 2
04 disco to 220,000 km is misfiring like crazy the plugs have changed the wires are changed it’s still misfiring the cats smell plugged what’s my next step?
Old Aug 9, 2022 | 08:58 PM
mln01's Avatar
Which cylinders are misfiring? Have you had the codes read? If the misfiring cylinders are all on one side, that gives us a clue.
Old Aug 9, 2022 | 09:06 PM
4th Gear
Default Here’s the list
This is the screenshot
Old Aug 9, 2022 | 09:08 PM
4th Gear
Old Aug 10, 2022 | 06:38 PM
Extinct's Avatar
5 and 7 are on different coils, so we can likely rule that out. Did you change wires recently perhaps, maybe you swapped locations? If not, start by swapping plugs with 1 and 3. If that does not work, you need to swap wires with 8 and 6. Then swap coils. After coils swap injectors with cylinders on that are not misfiring.
Aj6543
Feb 27, 2018 03:28 PM
allshookdown
Aug 29, 2016 10:45 PM
rchrd0413
Jul 14, 2014 07:59 AM
chrisr22
Jan 11, 2011 09:18 AM
gfeehan
Sep 1, 2008 09:41 AM
