Misfire then ok intermittent fault
Old Jan 18, 2018 | 03:55 PM
National1tyres's Avatar
6th Gear
Default Misfire then ok intermittent fault
Injector harness replaced ecu sent away tested fine fuel pump replaced fuel pressure regulator replaced all parts new
still have problems hard to start drives then cuts out when started can idle with no problems
seems to be when under load
Old Jan 18, 2018 | 04:03 PM
Alex_M's Avatar
Make sure your plug wires are on the spark plugs and the coils good. I had this exact issue; turned out one wire worked loose.
Old Jan 18, 2018 | 04:07 PM
LR03NJ's Avatar
What codes are you getting at the moment
flanker6
Dec 22, 2016 03:05 PM
MurphyPeoples
Mar 11, 2015 06:01 PM
06Range
May 8, 2013 09:01 PM
jeffmalone
Mar 13, 2010 09:23 PM
