Misfire under load
Old Feb 2, 2009 | 08:24 PM
turboedws6ta's Avatar
7th Gear
Default Misfire under load
I am a new owner of a 98 Disco. I bought it when it was not running. I diagnosed the biggest issue as the crank position senor. I replaced that, and it started right up. Upon driving it I found it to studder and misfire when under load. It idles just fine. It is throwing misfire codes. I had a suspision it was the fuel filter or pump, so I replaced the filter. I am only showing about 14-15 fuel pressure. So, I am pretty sure this is the issue. Most places in my area that sell fuel pump are selling the whole assembly. I am looking for a cheap way out if possible. Can a pump from a different vehicle be swapped in? How about a newer Disco? Thoughts?
Old Feb 2, 2009 | 08:44 PM
sloppyjoe's Avatar
Default RE: Misfire under load
what kind of gas are you running in it and have you swapped out the ignition components?
Old Feb 2, 2009 | 09:12 PM
7th Gear
I have not changed ignition components. It appears the previous owner has, although I have not verified if he did it to spec. I did verify that it had spark. I suppose that is obvious since it runs. Isnt the 14-15lbs fuel pressure an issue? I plan to review all ignition components tomorrow, anything specific to check on?
Old Feb 2, 2009 | 09:16 PM
NiteTrain's Avatar
yeah, 14-15psi for a fuel injected system is a problem..I am surprised it runs at all
Old Feb 2, 2009 | 09:19 PM
sloppyjoe's Avatar
yeah i kinda brain farted ,,,,
that pump is shot i am betting
Old Feb 2, 2009 | 09:41 PM
7th Gear
It doesnt sound strong at all when I turn the key to the on position. Sounds weak as can be. Does anyone know, can I substitute any other pumps other that the one made for a 98'? I have replaced pumps in the past, just not on a Land Rover. Is it a pretty std pump?
Old Feb 3, 2009 | 07:33 AM
7th Gear
There has to be someone that knows what other pump I can swap into my 98 disco!!! Throw me some thoughts!
Old Feb 3, 2009 | 09:23 AM
If you go to Rover Connection and check out the selection of fuel pumps, you will see that you must use a specific pump based on your vin.
What octane gas are you running, what are the exact fault codes you are getting?
Plan on ordering a set of 8 mm Magnacor wires if your truck still has the original grey wires.
Aggrov8
Jul 31, 2011 08:54 AM
DiscoNDixie
Mar 8, 2011 05:36 AM
jcostello
Feb 20, 2007 07:18 PM
jcostello
Oct 27, 2006 03:39 PM
Taipan
Freelander
Oct 15, 2006 02:52 PM
