maintenance questions
Old Feb 2, 2009 | 11:25 PM
sharp's Avatar
Default maintenance questions
For a new DIYer are there any nice videos or pics that show the many locations of screws and parts required to locate during the 60,000 mile service. The site www.discovery2.co.uk shows nice video for oil change and differentials but anything for changing a tranny filter, steering fluid or brake bleed?
I don't have a rave cd, I don't think it is mac compatible.
Old Feb 2, 2009 | 11:50 PM
NiteTrain's Avatar
Default RE: maintenance questions
i think you can get it on pdf
Old Feb 3, 2009 | 09:27 AM
If you need, Nice pictures, to do the 60,000 mile service, you may want to let someone else do the service whic includes the following list.
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil
12 Qts. of ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of synthetic DOT 4 Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant, also called DexCool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
1 bottle of WaterWetter or Purple Ice
Hoses and belts, as necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Change the coolant and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
TheWhiteRover
Jan 24, 2014 05:53 PM
SoCal Rob
Nov 4, 2013 03:16 PM
seamuspg
Sep 18, 2009 06:55 PM
Red Devil
Jul 18, 2007 12:08 PM
Shay108258
Aug 5, 2005 04:05 PM
