Mobil 0w40 motor oil
Old Sep 10, 2008 | 10:22 AM
  #21
Default RE: Mobil 0w40 motor oil
Once you switch to lab oil you will have leaks until the seals get soaked with the lab oil, then the leaks will stop.
Old Sep 10, 2008 | 11:19 AM
  #22
Landzu's Avatar
Ok whats lab oil ?
Old Sep 10, 2008 | 11:21 AM
  #23
Sorry, full synthetic.
Old Sep 10, 2008 | 12:38 PM
  #24
Switzer's Avatar
My Rover has no oil leaks. The only one I did experience was due to a clogged PCV valve which forced oil out the passenger rear valve cover (which is now fixed). I assume since Maxlife conditions the seals they should be better off now that I ran Maxlife for 6000 miles. I also think the Mobil 0w40 has its own additive package which also conditions seals and protects in ways other oils do not (sounds like an advertisement).
Once the seals are restored (somewhat) by the Maxlife oil I would hope the motor would not leak with 0w40 Mobil.
Cheers,
Pete
Old Sep 10, 2008 | 02:27 PM
  #25
I would switch and then never look back.
Engines get used to a brand of oil, once you switch to M 1 than stay with M 1, you can use different weights, but stay with one brand.
Old Sep 10, 2008 | 03:28 PM
  #26
Landzu's Avatar
Mobil One 0w40 is a Great oil in the right application.
SpeedAgent
Nov 1, 2019 07:30 PM
RedAustinIX
Apr 26, 2011 03:36 PM
lipadj46
Jan 11, 2010 03:38 PM
ek5usmc
Oct 9, 2008 04:33 PM
Landzu
Sep 29, 2008 03:59 PM
