Motor Mounts
Old May 3, 2012 | 08:24 AM
dparham's Avatar
Originally Posted by FlyingZebra34
One of mine is shot. I can't seem to find the right ones anywhere. Are they identical to each other or is there a left/right side? Any good sites to order them from?
Local part stores don't offer them.
HOw did you know yours was bad? I was told when I bought Disco that one of mine was bad but not sure of the signs... what were your signs it was bad?
Old May 3, 2012 | 08:38 AM
dgi 07's Avatar
Vibration at idle and on the throttle. And powerbrake the drivetrain. You see excessive movement, time for new ones. You will feel it all the time. Especially in the seat and pedals.
Old May 3, 2012 | 09:17 AM
dparham's Avatar
ok so similar to any cars ? I used to be in car business years ago and Id brake engine and little throttle and see if any movement in engine or bounce if bad... I have a rumbling and just a looseness is best I can feel... I was under truck before and after I rebuilt my drive shaft and could grab the front drive shaft and twist is back and forth (1/2" either direction) and hear a gears touching in the transfer case... drive shaft is solid, Im not as familiar with all wheel drives so not sure if this is normal play...
vandev
Jun 16, 2025 07:54 AM
FlyingZebra34
Apr 27, 2012 04:33 PM
Willie00d2
Feb 17, 2010 09:49 AM
btbaus
Nov 16, 2009 01:40 PM
aublec22
Feb 7, 2008 06:09 PM
