Motor swap and HG
Old Jul 29, 2016 | 05:52 PM
number9's Avatar
Charlie, for the bell housing bolts, do you mean something like this:
Wobble extensions are different animals.
Old Jul 29, 2016 | 07:02 PM
Jeff Blake's Avatar
Oh, those would have been nice... but guess what...
I GOT THEM. **** YEAH!!!
Most murderous thing I've done on the rover yet. Absolutely dreading putting these back.
This combo finally did the trick:
OK so I've pulled 10 bolts, and I see the top two left. However rave seems to say that there are 12 bolts PLUS the two top ones. I sure as heck don't see any more bolts.
Old Jul 29, 2016 | 10:21 PM
Fast951's Avatar
The top bell housing bolts are a real PITA. When I removed mine I supported the engine and transmission with a jack and some pieces of wood, disconnected the motor mounts from the chassis and engine and removed them completely. Then I lowered the jack about 4"-6" and the entire engine and transmission came down and away from the firewall. A lot easier to work up in there and remove the top bolts with the extra room.
Old Jul 29, 2016 | 10:29 PM
Jeff Blake's Avatar
Thanks for the tip - yeah I haven't even tried touching those top two yet because RAVE says to drop the engine as you've said. A flex-head ratcheting box wrench might work on them though, but I don't have one.
I don't have a lift so will be renting next week sometime - $30 for a day. Looking forward to starting the rebuild. I'm a little bummed out right now by the quality of some parts I'm buying - particular Allmakes rocker arms - they're very deformed and steel, not aluminum. Probably the worst thing is to spend money on aftermarket parts to replace your worn genuine parts --- but the aftermarkets are even more out of spec!! I think I like britpart the best. The lifters I received from Lucky8 look good
Old Jul 30, 2016 | 09:05 AM
evoblade's Avatar
Thanks for the tips guys. The project has been going extremely slow for due to moving for work but having to leave the LR. I work on it every time I get back home.
Old Jul 30, 2016 | 04:54 PM
Mskembo's Avatar
Originally Posted by drowssap
break the crank bolt free before you do anything else, and be as clean as possible, prime the pump with vaciline.
I read that as "prime the pump with vasoline" and was very confused.
Old Jul 30, 2016 | 05:13 PM
Alex_M's Avatar
<p>haven't read all the way through, but if you mean the oil pump then you do. Or at least can. I did.</p><p><br></p><p>
<br> <br> </p>
bennyb43
Dec 11, 2013 08:17 AM
me 2
Jun 17, 2012 07:24 PM
DuplinDisco
Apr 26, 2008 03:14 PM
kraelo
Mar 16, 2008 05:09 PM
