Multi double cardan front drive shaft
Old Jun 9, 2022 | 05:51 PM
DodyDisco's Avatar
Default Multi double cardan front drive shaft
Just wondering if anyone is running a multi double cardan shaft in the front.
First hand experiences with them in the front of a discovery are hard to find.
Fixing my castor put my driveshaft angles into a not so happy place. Havent measured angles yet but getting a vibration now.
Sporting a great basin rover HD shaft at the moment.
Old Jun 9, 2022 | 09:35 PM
Saturnine's Avatar
You make no sense sir.
Like a a pair of double cardan joints?
You might need a spacer depending on the suspension that I'm assuming you installed. Anything over a 3" lift could be considered for a spacer on the drive shaft. Doesn't matter what drive shaft you have now, is it serviceable? Have you serviced it? Does it need a rebuild? How are you "fixing" your castor?
Gotta have more info so that we can help.
Old Jun 9, 2022 | 10:41 PM
Dervish's Avatar
Don't know that much of the "scene" in the US, but how are You even thinking about having some diy two double cardan joints on a d2 front propshaft?
Even with a lift.
Just get a proper wide angle prop and be happy with it.
I have a 3" lift on my´03 TD5 and went for a Gwyn Lewis.
Old Jun 10, 2022 | 12:13 AM
DodyDisco's Avatar
Currently
4 to 4.5 inches of lift in front similar on the rear depending on load.
6 degree corrected front radius arms
Truck is evolving from its original 2 inch lift so i expect to spend some cash on hiccups.
Great basin rovers HD driveshaft in good shape fully greased up. Just had it off to inspect all is well.
I was attempting to not make a super long winded post.
The truck had no vibration issues before castor correction, Just super sketchy steering at speed.
The 6 deg of castor correction turned the pinion angle more extreme causing a vibration it seems.
Ill be measuring specific driveline angles as soon as i get another chance to get out there.
The shaft with Multi or Double double cardans is a Tom woods.
Ive seen these on strictly offroad vehicles at slow speeds. Never at freeway speeds. Hence looking for 1st hand accounts. They say its fine. But they also get the $$
Thanks for any insight. Much appreciated
Old Jun 10, 2022 | 05:30 AM
Alex_M's Avatar
I've never personally run one, but the multi double Carson shaft should be your fix. With a double Carson shaft you want your differential yoke pointing straight at your tcase output yoke. The two joints on the tcase end balance each other out and your differential joint is straight on this way, reducing harmonics. Now you've got one joint that has no matching joint at the same angle to soak up the harmonics.
Multi double cardon should be just fine on the highway. Again, I've never run them, but from my understanding that is your fix.
Old Jun 10, 2022 | 12:54 PM
Dervish's Avatar
Originally Posted by DodyDisco
Currently
Every day You learn something new.
Did not know those actually exist, but, I'm still a bit "fresh" on offroading etc.
hrhoward
Sep 22, 2016 01:59 PM
Simple8
Oct 26, 2015 07:55 AM
4x4ron
Mar 22, 2012 10:39 AM
glassman66
Feb 12, 2012 10:21 AM
mowthat
Mar 18, 2007 05:41 AM
