Multiple codes going off
Old Aug 30, 2020 | 03:41 PM
Names_James's Avatar
4th Gear
Default Multiple codes going off
I have multiple codes going off on my Land Rover and I can’t seem to find the problem.
could really use some help with this
Thanks
James
Old Aug 30, 2020 | 05:27 PM
Extinct's Avatar
Those are generic codes, you need to look them up specifically for a land rover. Does the truck run ok? The TCC is likely a battery voltage issue, my guess is the other major issue is a MAF issue
Old Sep 3, 2020 | 02:47 PM
4th Gear
my truck is a 2004 Land Rover discovery 2. She has a problem starting but once she starts it runs rough and fuse number 2 always blows
Old Sep 3, 2020 | 07:39 PM
Extinct's Avatar
Sounds like a MAF, don't remember what fuse #2 is. Look up the codes for LR specifically.
Old Sep 5, 2020 | 02:05 PM
4th Gear
fuse #2 is the engine management fuse and is a 15 amp fuse
Old Sep 6, 2020 | 12:54 AM
JUKE179r's Avatar
Do you have SAI?
Also check the wiring of your O2 to see if they are grounding out. Usually the right downstream O2 sensor wire will rub on the drive shaft.
Old Sep 18, 2020 | 02:21 AM
4th Gear
Originally Posted by JUKE179r
Do you have SAI?
if SAI stands for secondary air injection then yes my truck does have SAI and the wiring for the O2 sensor is still in good working order.
jfall
Sep 6, 2020 07:28 AM
jfall
Jan 7, 2013 02:43 PM
chad420
Jan 13, 2011 01:37 PM
JEFIII
Sep 8, 2010 09:12 PM
vinvelasco
Jun 28, 2008 02:38 AM
