my disco will not start, plus iam getting a # 14 code
Old Mar 26, 2007 | 07:15 PM
bmoore0211's Avatar
Default my disco will not start, plus iam getting a # 14 code
it will turn over with no problems at all, seems to spit once in awhile while iam trying to start it. Previously when it did run fine, it would take sometimes up to 3 times trying to start it before it did start and run. and twice in the last month it quit running while i was driving down the road , as if it had run out of gas.
And now all it will do is turn over, and not start up.
when i push in the pressue switch on the right side fuel rail, i get no fuel out of it at all, and i do not hear any noise out of the fuel pump either, where would the fuel relay switch be located at, so that i can check that with a test bulb.
My problem is i just got off my 3rd tour in Iraq, and iam stranded down here at Ft. Benning, Ga. and no way to get home, and i will not leave without my Land Rover Discovery..[/align][/align]PLUS IAM GETTING THIS CODE; CODE # 14[/align][/align]What is this code, i have a small code type black box that is attached to the vehicle under the passenger side front seat, when i try to startmy Disco, this code # 14 keeps coming up, what is this code, does anyone know, please let me know on this.
please help me on this.
thank you
Brian Moore
419-612-6910- Cell
brian.moore17@us.army.mil[/align]
Old Mar 26, 2007 | 07:59 PM
geoman's Avatar
Default RE: my disco will not start, plus iam getting a # 14 code
Brian,
Most likely it is the fuel pump itself-- which is immersed in the fuel tank. Access is through a hatch in the floor of the rear cargo area.
It is a common failure item on the Land Rover.
regards,
Geoman
www.eurotekapg.com
925-335-2669
Old Mar 26, 2007 | 08:03 PM
okdiscoguy's Avatar
Stay away from the platinum club by the Holiday Inn there.....
ngarover
Jan 2, 2013 08:31 AM
cer308
May 10, 2012 04:14 PM
sayeedA
Nov 15, 2011 11:02 PM
Snafu / Disco Fries
Apr 13, 2011 05:40 PM
starcraft
Mar 21, 2008 05:06 PM
