My Head Gasket Repair Punch List
Old Jan 18, 2018 | 06:16 AM
  #21
number9's Avatar
Originally Posted by mln01
and
3. Lettuce spray.
Thanks, lived all over the south all my life and never heard that one before.
Old Jan 18, 2018 | 07:36 AM
  #22
Lisa Bunch's Avatar
Bank loan, round tuit (key fob) and lettuce spray air freshener. Got it!
Old Jan 18, 2018 | 07:55 AM
  #23
CollieRover's Avatar
Originally Posted by Lisa Bunch
What's the plastic engine splash guard? An aftermarket part? Where do I get one? Thanks!
It’s actually fiberglass, not that that really matters. I got one from Paul Grant. It had two holes drilled into it for draining, which the first owner of it must have done, that is a good idea.If you are under it frequently it is a bit of a pain, but when I recently changed my starter I just moved it out of the way, and for my CPS job, it was not in the way at all.The only benefits I have noticed are first, it make it quieter. Second, it keeps Med etc. from the front of the engine. I decided to put one back on after my intermediate steering shaft rotted at the lower U Joint and was caked in dirt. I am hoping this prevents that happening to the new one.As for Electric fans, it is something you could accomplish at a later date. The reason I say this is that you could get the headgasket job done and have one less variable to isolate once it is back up and running. I am sure you will be obsessing about temps for a while. Once you’ve determined it’s operating normally, then you could switch. Just a thought.I have a Ron Francis AR99 controller, which is much beefier than the flex a lite, with relays etc., and fans out of an ‘05 GTO that needed trimming, but give me the most fan coverage possible IMO. As far as being waterproof, I used waterproof connectors from amazon for the connections for the fans, the controller in in my compartment behind the BCU/ABS. Also, they come with electric A/C fans, so will those blow out? I don’t know, I am not crossing rivers anytime soon so I am not concerned about it.Good luck! If you are **** retentive like me, I’d get the push in zip tie connectors for the injector wiring and other wiring along with any other ancillaries. Good luck!!
Old Jan 18, 2018 | 08:07 AM
  #24
Sixpack577's Avatar
The not adding an electric fan until after the head gasket job, as one less thing to cause any issues, is great advice.
Old Jan 18, 2018 | 09:08 AM
  #25
Alex_M's Avatar
Are you sure it's fiberglass? I was thinking glass fiber reinforced nylon. That said, I haven't seen one in probably 4 years.
Old Jan 18, 2018 | 09:14 AM
  #26
To be honest, I wouldn’t know the difference, between those materials, but it is definitely not plastic. You can see the fibers.
Old Jan 18, 2018 | 09:21 AM
  #27
Alex_M's Avatar
Fiberglass is glass fibers with an epoxy resin and GF reinforced nylon is glass fibers with plastic (specifically nylon). I do remember it being quite fiberous. It would've been a high percentage of glass fibers.
Old Jan 18, 2018 | 09:33 AM
  #28
You learn something new every day! No wonder my fiberglass “glue” didn’t fix the crack!
Old Jan 18, 2018 | 09:38 AM
  #29
Alex_M's Avatar
Haha, yep! Better bet would've been to "stitch" it back together with a soldering gun.
Old Jan 18, 2018 | 10:09 AM
  #30
Sixpack577's Avatar
Yeah, it has fibers, like fiberglass but not.
Was just easier to call it plastic.
You guys are too serious over parts you don't use, lol.
