My Head Gasket Repair Punch List
Old Jan 18, 2018 | 10:51 AM
  #31
petermasset's Avatar
Great list and I plan on using some items. Doing heads and pumps this month. My parts are on order and I'm just stockpiling the beer and patience.
Old Jan 18, 2018 | 12:47 PM
  #32
Best4x4's Avatar
Yep I have my 03-04 drip pan laying on the bench in my shop. To mount it to earlier 99-02 D2’s properly it’ll require two small brackets to support it. On 03-04 D2’s it’s riveted to the frame.
Old Jan 18, 2018 | 12:58 PM
  #33
number9's Avatar
5. Remove 7 screws securing underbelly panel.
Odd that some '04 including mine have/had screws holding the panel in place.
Old Jan 18, 2018 | 01:12 PM
  #34
Alex_M's Avatar
My 03 had screws as well from what I remember.
Old Jan 18, 2018 | 01:13 PM
  #35
Best4x4's Avatar
Let me be “crystal” clear here down to the color of the plastic inserts in the frame for the 8mm/phillips head mounting screws.... The rear brackets for the 03-04 drip pan is secured to the frame via rivets, then you attach the drip pan to the bracket via two 8mm/phillips head screws (one per rear side), then the front of the drip pan is attached with yellow inserts in the frame and several more 8mm/phillips head screws.The rear brackets are not meant to be removed hence the rivets from the factory. 99-02 D2’s do not normally have those brackets riveted to the frame. Sure you could slap it on via the front 8mm/phillips head screws with the yellow plastic tabs in the frame, but the back will not be secured without those brackets or something you make to support it.
Old Jan 18, 2018 | 01:16 PM
  #36
Alex_M's Avatar
Ah, that makes sense.
Aaron Sandland
Nov 14, 2017 10:26 PM
LandRoverDisco03
Jan 16, 2015 10:04 AM
primussucks
Jun 20, 2012 11:15 PM
Robwsup
Mar 11, 2010 10:28 PM
chris03653837
May 1, 2009 03:03 PM
