Is my power steering pump going bad?
Good morning yall
When ever I go to full lock to the left, my truck started making a noise and feeling like something was grinding. And at high speeds 60+ Mph the steering wheel will shake, not too crazy but I think it could be related.
Also the steering wheel is slightly turned to the left when driving straight
What do you think it could be?
I haven’t done anything to the steering system (at least not on purpose)
My only thought is power steering but I guess it could be a bushing or a bearing.
I still consider myself new to fixing my car myself but I’m trying to get more com
power steering usually makes a whining noise i don't think it will cause your issues, i think you have something else going on, you should check the usual ball joints bearings etc, and make sure your tires are balanced, and get a alignment, after the alignment your steering wheel should be straight, i had this problem recently on my subaru, it ended up being my tie rod ends,
TyTyBinks (09-14-2021)
tires can definitely do that. replace them if you need to anyways and then go from there. new tires cured my vibration at 75.
