Power steering issue
Old Jun 21, 2010 | 10:17 AM
Long Haul's Avatar
Default Power steering issue
Ive searched the forum without much luck regarding my problem.. Its a 98D1 with 170000 miles. My problem is when its hot its like i dont have any power steering at all, I replaiced the steering damper thinking it had some thing to do with that no different. Ive flushed the system a couple times still no different. I guess what im asking is if its the pump or gear box problem?
Thanks in advance,
Brian
Old Jun 21, 2010 | 11:39 AM
All the steering damper does is prevent the steering wheel from breaking your arm when you hit a big bump or a rock while offroading.
What fluid did you use in the power steering?
Old Jun 21, 2010 | 11:48 AM
Long Haul's Avatar
Well my damper was dented and bent so it had to be replaced. There was ATF in the resavoir so thats what i replaced it with.
Old Jun 21, 2010 | 11:50 AM
Ok, good. The DI power steering system uses Dexron III.
Sounds like your pump is on its way out assuming that your serpentine belt and tensioner is good.
Old Jun 21, 2010 | 11:59 AM
Long Haul's Avatar
Yeah new belt nd tensioner less than 3000 miles ago. I was afraid you were gonna say pump was goin out
Old Jun 21, 2010 | 06:54 PM
discoxd's Avatar
i havent had power steering for over a year... power steering is a crutch
Old Jun 21, 2010 | 07:30 PM
But you drive the "Short Bus", aren't you supposed...
tw_salisbury
Mar 10, 2013 06:26 PM
03DiscoSE
Mar 30, 2012 08:43 AM
blcp86
Jan 14, 2010 06:41 PM
eandrews2
Aug 4, 2008 04:02 PM
