Is my power steering pump going bad?
Old Sep 14, 2021 | 05:46 AM
TyTyBinks's Avatar
Default Is my power steering pump going bad?
Good morning yall
When ever I go to full lock to the left, my truck started making a noise and feeling like something was grinding. And at high speeds 60+ Mph the steering wheel will shake, not too crazy but I think it could be related.
Also the steering wheel is slightly turned to the left when driving straight
What do you think it could be?
I haven’t done anything to the steering system (at least not on purpose)
My only thought is power steering but I guess it could be a bushing or a bearing.
I still consider myself new to fixing my car myself but I’m trying to get more com
Old Sep 14, 2021 | 05:50 AM
TyTyBinks's Avatar
Also I just did all 4 brakes (pads, rotors, 2 rear calipers, hard brake lines and SS brake hoses)
As well as the head gasket almost 7 months ago
incase this has anything to do with it
Old Sep 14, 2021 | 06:46 AM
redwhitekat's Avatar
power steering usually makes a whining noise i don't think it will cause your issues, i think you have something else going on, you should check the usual ball joints bearings etc, and make sure your tires are balanced, and get a alignment, after the alignment your steering wheel should be straight, i had this problem recently on my subaru, it ended up being my tie rod ends,
Old Sep 14, 2021 | 06:57 AM
TyTyBinks's Avatar
Thanks I’ll get an alignment soon
Old Sep 14, 2021 | 07:01 AM
TyTyBinks's Avatar
And my tires are pretty close to being worn out so I think I’m going to order new tires and then get them mounted and alligned like that
Old Sep 14, 2021 | 10:18 AM
tnrangerover's Avatar
tires can definitely do that. replace them if you need to anyways and then go from there. new tires cured my vibration at 75.
unstable
Feb 21, 2012 06:07 PM
Long Haul
Jun 21, 2010 07:30 PM
range03
Apr 14, 2009 06:33 AM
jwfuller
Apr 23, 2008 08:57 PM
humroot
Nov 11, 2007 08:58 PM
