My Ticking Disco Problem - SOLVED
Old Jun 10, 2015 | 08:26 AM
  #121
Tony Luna's Avatar
Originally Posted by CRB357
Well?
Wasn't the PS pump...
I have new rocker arms and shafts on the way.
If that dosn't solve the issue, only thing left to do is pull the motor and pin the liners. At that point it's all new bearings and rings too.
Old Jun 10, 2015 | 08:44 AM
  #122
CRB357's Avatar
Thanks for responding. I hope the rocker arms and shafts work.
Old Jun 10, 2015 | 12:31 PM
  #123
DustyLBottoms's Avatar
Wasn't the PS pump for me, either.
Old Jun 11, 2015 | 12:36 AM
  #124
Tony Luna's Avatar
Yeah, me too.
Old Jul 25, 2015 | 08:02 PM
  #125
Tony Luna's Avatar
New rocker arms and shafts... Still ticks.
To recap all of this going back a few months.
190K. Runs quiet when cold, ticks at idle, tick goes away at 1,200 RPM. Wife's DD until a few months ago. Well maintained.
Good oil pressure cold/hot, idle/2K RPM. Rotella 15-40W.
Good compression in all cylinders 149-151.
MMO treatment.
New radiator and genuine 180 degree t-stat - no coolant leaks.
New plugs.
New front cover/oil pump.
New timing gears/chain.
New PS pump.
New cam, lifters, rocker arms, and shafts.
Runs better than ever - great power and super smooth.
Still ticks when warm.
Old Jul 26, 2015 | 08:37 AM
  #126
fishEH's Avatar
Forget it. You're going to drive yourself nuts looking for the tick, or spend a lot more money. Its not worth it. Drive it till it dies.
Old Jul 26, 2015 | 01:50 PM
  #127
erick846's Avatar
MMO treatment.
New plugs.
New PS pump.
What degree does it start ticking at? It's still a slipped sleeve, albeit very early on
Old Jul 26, 2015 | 03:21 PM
  #128
OffroadFrance's Avatar
TC flex plate failure is an LR 'speciality' unfortunately. Towing heavy loads exacerbates this problem.
Ashcroft Transmissions
Ashcroft sell an HD flexplate and also an HD TC.
Old Jul 26, 2015 | 03:24 PM
  #129
X1 I can recall worrying myself to death many times about a clicking and dead spot when I used to race Caterhams in the Vauxhall 16V challenge until I realised I was on the rev limiter
Old Jul 27, 2015 | 06:35 AM
  #130
drowssap's Avatar
the fact that the tic goes away after 1200 rpm would direct me to a liner.
