My Ticking Disco Problem - SOLVED
Old Jul 27, 2015 | 12:14 PM
  #131
Tony Luna's Avatar
Originally Posted by fishEH
Forget it. You're going to drive yourself nuts looking for the tick, or spend a lot more money. Its not worth it. Drive it till it dies.
Wish I could... Having been a helicopter flight mechanic in a former life + OCD won't allow me to let it go.
Old Jul 27, 2015 | 12:16 PM
  #132
Tony Luna's Avatar
Originally Posted by erick846
What degree does it start ticking at? It's still a slipped sleeve, albeit very early on
Either that or piston slap? Still intermittent. I think I can consistently make it stop. More to come...
Old Jul 27, 2015 | 12:31 PM
  #133
Tony Luna's Avatar
Originally Posted by drowssap
the fact that the tic goes away after 1200 rpm would direct me to a liner.
That's what I'm leaning towards. I keep bouncing back and forth between a Turner SB and replacing the slipper(s) on my block w a top hat sleeve(s) and a "pin job". On a separate note, I think I may have come across a trick to consistently make the ticking stop. Just want to make sure it really works before posting about it so I don't sound like a clown...
Old Jul 27, 2015 | 12:35 PM
  #134
drowssap's Avatar
at a certain rpm the actual piston speed becomes quicker than the liner can bottom out and the noise will quite down.
Old Aug 13, 2015 | 07:26 PM
  #135
Tony Luna's Avatar
I replaced my fan blade with an '02 version and installed a new fan clutch (Hayden 2991).
I've been running for about a week and a half with ZERO ticking - idling for long periods of time with the AC on in 90+ degree weather (I hope posting this doesn't jinx me).
It is a bit louder, but not too bad. The new fan set up and all the previous work has her running better than she has in years!
I also bought all the components to do the in-line 180 degree t-stat mod, but I'm reading mixed reviews between using the genuine 180 degree t-stat (which I have - new) and doing the in-line mod...
Also thinking about adding an oil cooler. For those who know, would this make things too cool? Can such a thing (running too cool) be done?
Old Aug 13, 2015 | 07:54 PM
  #136
Charlie_V's Avatar
My 2000 have an oil cooler. I didn't even know you could buy one without an oil cooler until I took an 03 apart. Not only should you have an oil cooler, I would--and a going to--swap my oil cooler for a larger transmission cooler that still fits the brackets.
I think your ticking is the lifters. As the engine gets hotter, the oil gets thinner. The thicker, cooler oil is just enough to hold your lifters still. That's my theory anyway.
Old Aug 13, 2015 | 08:08 PM
  #137
Tony Luna's Avatar
Brand new timing gears/chain, cam, lifters, push rods, rocker arms and shafts, and oil pump - amongst a bunch of other stuff...
Old Aug 13, 2015 | 08:11 PM
  #138
Charlie_V's Avatar
Well it was just a theory. Haha.
Dang, then that might be a sleeve.
Old Aug 14, 2015 | 12:10 AM
  #139
Tony Luna's Avatar
I'm sure it is, but if efficient - and improved - cooling can keep it at bay, I'm all for it.
Old Aug 14, 2015 | 12:24 AM
  #140
Charlie_V's Avatar
Well if you ever get excited enough to PIN your sleeves please let me know. Photos of your success might just be the nudge I need to do mine.
