Need an accurate steering bar/Drag link measurment Porfavor!
Old Jun 28, 2016 | 09:42 PM
bosshogt's Avatar
Default Need an accurate steering bar/Drag link measurment Porfavor!
Hello all,
I am about to replace my factory LR steering bars with the Terrafirma HD TF255 steering bars and new tie rod ends. The rear drag link has been bent by a rock hit earlier this year so I cannot use it as an accurate measurement end-to-end. If some one could give me an accurate measure for the front and rear on-center of the tie rod bolts that will get me started with a good toe in.
I have been unable to find that measurement anywhere in the RAV
After speaking with the guys from British 4x4 Centre in Texas they said to start by measuring 1/4" to 1/2" wider in the front than the back on a consistent tire lug. Does this sound like a good way to go?
Old Jun 28, 2016 | 10:23 PM
Alex_M's Avatar
I'll be working on my truck tomorrow and I'll get you that measurement to get you started, though I'd say it will be relatively close as is. I did 1/4" toe out I believe, so 1/8" wider in the front than the rear. That seemed to work best. I will double check that measurement for you because I did some rather extensive testing on what worked best for me.
Old Jun 28, 2016 | 10:49 PM
bosshogt's Avatar
Thanks Alex it rained on me tonight so I will hold off till tomorrow night
Old Jun 29, 2016 | 12:08 AM
chubbs878's Avatar
It's come time for me to update my steering linkage and having trouble deciding what to buy. NAPA has OE Lemforder* tie rod assembly for $160. But I also need the drag-link ends higher up so I started looking into the HD kits that include upgraded bars and all new joints as a kit with everything needed. Finally I was browsing EBay where I found that I could buy a set of 4 new ball joints for a good price, as there is nothing wrong with my bars. I would like some suggestions and personal preferences to assist in making a final decision on the quick.
Old Jun 29, 2016 | 07:13 AM
Alex_M's Avatar
If you have stock bars, those wont work. Only one ball joint on each bar is replaceable.
Old Jun 29, 2016 | 06:06 PM
bosshogt's Avatar
Yep the tie rod end on the passenger side drag link is fixed/pressed in the steering bar.
Old Jun 29, 2016 | 07:06 PM
Alex_M's Avatar
37-1/8" for the front bar, 50.5" for the rear bar. My front is 1/4" wider than the rear.
Old Jun 29, 2016 | 07:15 PM
Alex_M's Avatar
That's center to center, by the way.
Old Jun 29, 2016 | 11:49 PM
bosshogt's Avatar
Thanks Alex for the measurements! I will get working on that probably tomorrow night.
Found my other problem with the brakes from my other post...i researched on other LR forums. A bad master cylinder back flow valve with a 0.2mm hole. As brakes heat up they need to release fluid back to the reservoir. A few pieces of debris or crystallized brake fluid clog that hole then after 10mins of driving all 4 brakes lockup like a nuns legs in a ***** house. Seems to happen on the highway only at first but then happened on city streets tonight. I ordered a new TRW master cylinder tonight. That is the genuine rover OEM brand. Just replaced it about 4 months back from AB. But I guess it was defective. I've heard they are not rebuild-able yet from a few mechanics. Would love to have reliable brakes again. Need to be able to stop this tank quickly
fishEH
Aug 14, 2012 06:02 PM
00Balls
Jul 16, 2012 08:54 PM
bmwrovers
Jun 4, 2009 06:17 PM
Disco Alan
May 13, 2009 12:34 PM
Disco2Guy
Jul 19, 2008 02:23 AM
