need help CDL shifter install
Old Mar 25, 2010 | 10:11 PM
NiteTrain's Avatar
Default need help CDL shifter install
put the D1 shifter in my DII and can get the lever on the nipple but can't get it to engage...there are 2 pivot points i must have them in the wrong place..does anybody have a pic of a D1 CDL shifter installed showing how the lever attaches to the nipple?
Old Mar 26, 2010 | 12:49 AM
NiteTrain's Avatar
figured it out. forgot to attach cdl lever to that eye bolt.
Old Mar 26, 2010 | 10:48 AM
hilltoppersx's Avatar
Old Mar 26, 2010 | 01:55 PM
NiteTrain's Avatar
its all back together now and i hope to God i never have to get under that console again
Old Mar 26, 2010 | 02:12 PM
Camdisco24's Avatar
I know exactly what you mean!
That might be the most annoying thing to take out on any land rover.
Old Mar 26, 2010 | 02:34 PM
Danny Lee 97 Disco's Avatar
Default Console Mod
I have mine all out from working on my cdl shifter on my 97 DI. The linkage was totally frozen with accumulated crud. I had to take it all apart, replaced all the little clips and clevis pins, got the high low shft working, the diff lock still would not engage until I replaced the switch, the plunger was frozen on the old switch. You could move the shifter put never get CDL Locked. With new switch I finally got CDL locked and the little dashboard 4 wheel symbol lights right up. I verified switch engagement with ohmmeter after replacement.
Then I took it up the ramp and around the neighbors backyard. Sure is nice to have all that working.
I cut my console in half with a coping saw while I had it out. I plan on mounting it so either half could be easily removed without the hassle of undoing all the window switches to get to the CDL linkage. It was easy to cut apart.
Old Mar 26, 2010 | 03:45 PM
id like to see a photo of your console cut in half
Old Mar 26, 2010 | 03:50 PM
Camdisco24's Avatar
Same here.
Can you see where you cut it when its all back in place??
Old Mar 30, 2010 | 10:11 AM
gran3smo's Avatar
[quote=Danny Lee 97 Disco;169585]I have mine all out from working on my cdl shifter on my 97 DI. The linkage was totally frozen with accumulated crud. I had to take it all apart, replaced all the little clips and clevis pins, got the high low shft working, the diff lock still would not engage until I replaced the switch, the plunger was frozen on the old switch. You could move the shifter put never get CDL Locked. With new switch I finally got CDL locked and the little dashboard 4 wheel symbol lights right up. I verified switch engagement with ohmmeter after replacement.
What switch?
This is the same problem I'm having. Linkage moves freely as well as the arm on top of the T-case but no diff lock engagement. In fact the light has never come on and I know it's not just a burned out light.
turbodave
Mar 29, 2019 07:22 AM
nosup4u
Apr 16, 2014 08:33 PM
Francopacks
Apr 30, 2013 12:33 AM
dcarr1971
Oct 26, 2010 01:26 PM
03discoman
Nov 2, 2009 07:29 PM
