need help changing spark plugs and correct gapping
Old May 1, 2010 | 07:01 PM
  #21
hilltoppersx's Avatar
if you use the Bosch +4 plugs they are pregapped. but the gap information should be in two places. under the bonnet and in the RAVE.
Old May 1, 2010 | 07:22 PM
  #22
lipadj46's Avatar
The gap for a DII should be 0.038 - 0.042 as per the rave.
Old May 1, 2010 | 09:33 PM
  #23
tornado_735's Avatar
I have plain ole copper Champs in mine, and she seems to do just fine.
Old May 2, 2010 | 05:55 PM
  #24
Danny Lee 97 Disco's Avatar
Originally Posted by hilltoppersx
magencores are cheap @ www.apexperformance.net
They show 7mm for 80, 8 mm for 85, and 8.5 mm for 100.
Mine are Lucas, so most likely they are originals.
Old May 2, 2010 | 06:12 PM
  #25
greg409's Avatar
Classklown90 - that's an example of a hijacked thread.
As I said ealier, I used autolites (.034" gapped - rave cd says .035--.040") I always gap new plugs close.
I use autozone silicone wires $50
They've been in my truck for 5yrs. so far, it runs great.
download the rave cd below
luck,greg
Old May 2, 2010 | 06:16 PM
  #26
Classklown90's Avatar
haha yea and thanks for the pm greg. ill give them a try. how much do they run? at say pepboys or autozone?
Old May 2, 2010 | 08:55 PM
  #27
greg409's Avatar
Shoot, I can't remember to take out the garbage! LOL
I'm sure I bought those @ autozone.
As I said, the wires were around $50, the cheap ones won't be silicone, so they're susceptable to heat and it gets hot under our hoods.
The better wires will also have di-electric grease in the boots to combat corrosion.
I'm cheap, so they couldn't have been too bad.
I'm selective about brand name usually, if the part sees abuse, (brakes, ujoints,belts, etc.), I generally buy the good stuff, it lasts longer.
luck,greg
Old May 2, 2010 | 09:25 PM
  #28
audiS4S6's Avatar
Is anyone concerned that there are 26 posts on changing spark plugs???
Old May 2, 2010 | 09:31 PM
  #29
audiS4S6's Avatar
ALWAYS check the gap before installation (I am sure Hilltopper would agree). Even pre-gapped plugs can get bumped or dropped so you never really know.
p.s. I love seeing "bonnet" instead of hood.
Old May 2, 2010 | 09:34 PM
  #30
elboy0712's Avatar
Default here where i got my sensors for 60 bucks
http://www.amazon.com/NGK-25623-Oxyg...tive&carId=002
and there are other options if you dont like the brand then use the part finder...
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
spirex
Jan 8, 2013 10:58 AM
cobra29
Jun 19, 2010 05:38 PM
pbgelber
Aug 6, 2008 09:47 AM
MidasHands
Freelander
Jun 5, 2008 05:50 PM
