Need help quick!
Old Dec 30, 2010 | 01:17 PM
willrok13's Avatar
Default Need help quick!
I swapped for remnufactured heads and lost track of which head came off of which side. Are the RH and LH heads the same? Thanks!
Old Dec 30, 2010 | 04:49 PM
JEFIII's Avatar
Willrok13,
As far as I know, the heads are identical. I just installed my heads last Friday and lost track as to which was which myself. (although I think I figured it out...) They should have the exact same casting numbers so they can go on either way. Hope this helps and makes you feel better. JF
Old Dec 30, 2010 | 05:16 PM
antichrist's Avatar
No difference between right and left.
I don't see how you could mix up reman heads anyway, since you have no way to know which side they were on to start with.
Old Dec 30, 2010 | 06:19 PM
willrok13's Avatar
Thanks for the help. I didn't mean "mix up" so much as forgot to inquire which was which - or make a mental note of which one matched the one I removed. I took some time and thought through it then determined they are identical.
icyhot201
Aug 16, 2010 07:24 PM
endneu913
Nov 3, 2007 03:46 PM
suntattoo80
Feb 14, 2007 09:25 PM
Brad S1
Jan 26, 2007 11:31 AM
Disco Girl
Nov 7, 2006 10:47 AM
