Need some help can't locate in rave
Old Feb 8, 2014 | 12:45 PM
wynhd's Avatar
Default Need some help can't locate in rave
I changed out my master cylinder resivoir with a kit from AB, all went fine till I went to reinstall. I have a metal oring and I am unsure where it goes. The kit came with 2 rubber orings and 2 grommets for the resivoir to sit on. Any assistance would be greatly appreciated. I am hoping the attached pic helps someone assist me. Thanks in advance.
Old Feb 8, 2014 | 02:34 PM
marizcal's Avatar
ok.. I just do the same for my disco and as long as I remember it goes inside the yellow plastic,, see the pic... first goes one of the o-rings, smallest then
the part that you ask for ...
Old Feb 8, 2014 | 03:24 PM
04duxlr's Avatar
This might help: https://landroverforums.com/forum/sh...5945&styleid=4
Old Feb 8, 2014 | 07:04 PM
wynhd's Avatar
Now I can't bleed the brakes... Even removed the nipple and nothing comes out... Any ideas?
Old Feb 8, 2014 | 07:20 PM
jafir's Avatar
Bleed the lines where they are going into the ABS modulator from the master first, they maybe have emptied when you worked on the master.
Open the line, have someone push the pedal half way down or so, close the line, release the pedal. Repeat for the other line going in. You might not get a firm pedal right away, but it should get enough that you can bleed normally at the wheels.
Brokenrover
Jan 22, 2010 12:44 PM
ALEXAN
Sep 8, 2009 10:17 AM
JBEGIN
May 5, 2009 07:46 PM
Evian
May 17, 2006 07:14 AM
skydivdav
Mar 7, 2005 12:36 PM
