Need some help regarding loud noise when putting in R or D
Old Aug 26, 2009 | 07:01 AM
hilltoppersx's Avatar
you replaced both the front and back?
Old Aug 26, 2009 | 07:03 AM
lipadj46's Avatar
Yeah check the U-joint in the back too.
Old Aug 26, 2009 | 10:11 AM
Originally Posted by KBW
Sometimes when I start the vehicle and put it in Drive or Reverse it will make a loud clunk. Thought that was the driveshaft so I replaced it (almost 60k on my vehicle so the ds needed replacing anyway). For the first two days after installing the TW I didn't notice the problem. Today leaving my driveway it was loud and it happens especially when my vehicle is on an incline. Is this probably something with my transmission or something? It is loud and sounds pretty rough when it happens. If I'm stopped on an incline and put it in reverse it sounds like something is about to break. Doesn't make noises when I'm moving and the automatic transmission shifts gears.
So how often do you lube the drive shaft???
Have you checked to see if it is failing?
Send me your tele number, we should talk, in the mean time, DON'T drive it.
Old Aug 26, 2009 | 05:29 PM
KBW's Avatar
KBW
Mike the drive shaft is like 5 days old . It was lubed up the max when I put it on last saturday so that isn't the problem (hopefully at least). My # is in your inbox
Old Sep 1, 2009 | 08:09 PM
03vojett's Avatar
6th Gear
Well, I had that problem. Clunking from P to D or R to D. I ended up having a broken U-joint on the front drive shaft. I replaced that and the clunking stopped. Just a thought.
Oasisplayer311
Jan 21, 2015 12:23 AM
DiscoShelt
Dec 17, 2014 01:11 PM
capthook
Apr 10, 2012 09:20 AM
2003DICSO
Aug 7, 2009 06:13 PM
