Need Urgent Advice - okay to re-use old valve cover bolts?
Old May 8, 2023 | 09:34 PM
Brandon318's Avatar
Originally Posted by acg
So... since I am using the original ones.... is there any type of high heat thread lock stuff that we should use?
I also read somewhere that they should be torqued last a little more than the prescribed 6 lb-ft.... but not more than 10 lb-ft (to prevent completely crushing the tiny valve gasket hole metal bushings.... but still tight enough to seal the gasket. Thoughts?
The original valve cover gaskets came installed by a shop with the new Turner engine 3 years ago. It started leaking like a baby's diaper within a year. It has been re-tightened twice and the leaking has not stopped.
Therefore, today is the day to completely replace to new gaskets. Fingers crossed on these new FEL-PRO gaskets.
I use blue Loctite. I also finally bought an in-lb torque wrench because I was so tired of the valve cover leaking. After using that and torquing to spec, haven't had a leak from a valve cover since.
Old May 9, 2023 | 05:24 AM
Extinct's Avatar
Blue loctite works, or just plain old silicone. You are basically torqueing it till the valve cover squeezes down to the steel bushing and then just snug on the bolts. The bushings keep us from squeezing the gaskets out. Obviously LR decided they needed patches on the bolts because of the problematic loosening.
Old May 9, 2023 | 12:19 PM
Externet's Avatar
I discarded mine and replaced with bolts that do not need an 'special' tool to remove them, and they have not moved nor created leaks in 10 years.
wes_in_va
Aug 3, 2022 03:20 PM
bmeier
Apr 16, 2021 06:18 PM
twin6
Jan 25, 2017 09:17 AM
rod76
Oct 30, 2009 04:43 PM
igriego
Jan 17, 2009 11:35 AM
