Negative battery terminal replacement plan
Old Apr 13, 2016 | 05:29 AM
batard's Avatar
Default Negative battery terminal replacement plan
I'm planning to cut the negative terminal off with a dremel, crimp on a lug ring -- something like
this this
then bolt down the ring to a terminal like
this this
and put that on the terminal.
I did some looking around in the forums and it seems like people have done similar things. My biggest concern would be I'm not sure the cable will still be able to reach the terminal after I cut it and swap it out. Am I on the right track?
NB I'm considering doing this because my current negative terminal is a bit beat-up and isn't tight enough even when fully tightened. I'm planning to try to fix this either by shimming, inserting a screw in there, or hacksawing off the end of one of the crimping wings so it can compress more, but I want to have a backup in place in case these things don't work.
Old Apr 13, 2016 | 09:26 PM
mln01's Avatar
Can you post a pic of what your existing negative clamp and post look like? I'd try a lot of things before cutting off the original terminal.
RawFaith
Jan 20, 2016 06:09 PM
coors
Feb 4, 2011 10:08 AM
tsuami1
Jul 1, 2010 07:02 AM
karover
May 28, 2010 07:05 AM
FTB 2000 Disco
Dec 4, 2006 12:03 AM
