New ABS Sensor Causing Dashboard Brake Light
Old Oct 19, 2015 | 10:47 AM
Titus's Avatar
Default New ABS Sensor Causing Dashboard Brake Light
I have had the dreaded three amigos for years now and finally got around to trying to resolve them. The only code was a bad front left sensor output. I replaced the sensor this weekend and in addition to still having the same code, the Brake light on the dash is now illuminated. If I disconnect the sensor then I only get the three amigos (no Brake light).
Any thoughts? I am assuming the new sensor is also bad and that it is causing the Brake light to come on.
Old Oct 19, 2015 | 10:52 AM
Joemamma1954's Avatar
From what I understand, the brake light is only triggered by low brake fluid(sensor in cap) and the emergency brake switch. I may be wrong, but check those two things.
Old Oct 19, 2015 | 11:40 AM
Titus's Avatar
Thanks for the response. I actually already checked both of those since that was what I thought as well. Plus the fact that I didn't touch either of them during the ABS sensor replacement.
I believe an electrical fault will also cause the light to illuminate but the timing suggests that it is due to the sensor.
FlyingZebra34
Nov 19, 2013 03:07 PM
vandal996
Feb 17, 2011 09:44 AM
icoolyou
Dec 17, 2007 02:33 PM
rebooTT
Jun 20, 2005 01:09 AM
